Editing Boolean Properties
Boolean check boxes differentiate between “applies” and “does not apply.”
To edit a boolean property:
  • Select an empty check box to set the property to “true.”
  • Deselect the check box to set the property value to “false.”
  • Click in the check box and press the Spacebar to toggle between “true” and “false.”
(default, auto-save enabled) Your changes are immediately saved. If auto-save is disabled, click the Save button to save your changes.
