Metadata Tab Shortcuts
Keyboard shortcuts available when working in the Metadata tab are listed in the following table. Some keystroke combinations only work when the cursor is located in a certain section or property; the Focus column in the table specifies the section of the tab when that is the case. For more information on the tab, see Working with Metadata.
Shortcut |
Description |
Focus |
Tab |
Navigate to the next editable field. Leaving an edited field by pressing the Tab key saves the changed value. |
Metadata tab |
Tab
Advance to the input control at the right side and navigate to the next editable field within the row
Master Data edit window |
Tab
Advance to the input control at the right side within the attribute
Date, Time, DateTime |
Shift (hold) + Click Ctrl (hold) + Click |
Used to select multiple consecutive rows Used to select multiple non-consecutive rows |
Multi-value, Compound or Master Data edit window |
Up Arrow Down Arrow |
Used to navigate to the previous row Used to navigate to the next row |
Increase value Decrease value |
Move to the beginning of the field Move to the end of the field |
Duration, Integer, Float, Timecode, Text |
Move cursor to the line above Move cursor to the line below |
Text (multi-line) |
Home End |
Home End |
Move to the beginning of the line Move to the end of the line |
Text (multi-line) |
Left Arrow Right Arrow |
Advance to the input control at the left side Advance to the input control at the right side |
Advance to the character/figure to the left side Advance to the character/figure to the right side |
Delete / Backspace |
Delete the selected row(s) |
Delete the selected text or figures |
Integer, Float, Date, Time, DateTime, Text |
Esc |
Cancel the Delete row(s) action |
Esc |
Keep the already selected term |
Legal list, thesaurus |
Esc |
Discard your input, keep the original value and end editing mode. If you press the Esc key when editing one of the supported property types within a multi-value compound or master data edit window, editing mode is only ended for the individual property not for the entire row. |
Date, Time, DateTime, Duration, Integer, Float, Text, Timecode |
Ctrl + A |
Select the entire text |
Text |
Ctrl + C |
Copy the select text |
Text |
Ctrl + V |
Paste copied text, duration, timecode |
Text, Duration, Timecode |
Ctrl + X |
Cut the select text |
Text |
Ctrl + Y |
Redo the action |
Text, Float, Integer |
Ctrl + Z |
Undo the input |
Space |
Checks or unchecks the in-focus check box |
Boolean |
