Setting the Default Save Location for New Sequences
You can set the path for a folder in the Production Management database to store new sequences. If you are working in a multi-site environment, the settings allows you to select a location in your local Production Management system only.
To set the default save location for new sequences:
  1. Click the User Profile button on the right side of the Fast Bar and select User Settings.
    The User Settings dialog box opens.
  2. In the navigation panel, select the settings group Save.
  3. In the Sequence section, click the drop-down menu and select the save location path.
  4. Click Save.
