Using the Search App's Transcript Status Information
In addition to the Transcript tab and Process app, you can also get information about the transcript status of a master clip or subclip within the Search app. In the case of a subclip, the Transcript Status column reports the status of the parent master clip.
To use the Transcript Status information in the Search app:
Open the Search app.
Click the Display options drop-down menu.
Select the Transcript Status check box.
Click an area outside of the menu to apply your change.
The Transcript Status column is shown in the Results area on the far right.
You might reorder the column by dragging the column header to the left.
Search for master clips or subclips or both of an Avid Production Management/local Production Management module.
Inspect the information in the Transcript Status column.
Icon
Transcript Status
<none>
The asset has not been transcribed (or attempted to be transcribed).
Pending: The transcribe job is in queue, waiting to be processed.
Running: The transcript creation is in progress.
Paused: The job was paused while it was processing.
Completed: The transcript job completed successfully.
Failed: The transcribe job failed to complete successfully.
Cancelled: The transcribe job was started and actively canceled.
