Adding Storyboard Items to a Sequence
You can add items from the Storyboard tab by a simple drag and drop operation to a sequence. In doing so, you add a segment to the sequence.
You can add one or more markers or restrictions or segments at the same time to the sequence. Note the following limitation: Adding more than one stratum segment at the same time to a sequence is currently not supported. For thumbnails, adding an individual thumbnail or a range of consecutive thumbnails is supported.
c The term sequence is used generically throughout this topic to refer to an assembly of audio and video assets; it refers to any or all sequence types.
For more information about sequences, see Understanding Sequence Types and Working with Sequences.
Note the following effects when adding items to a sequence:
For each added marker, a segment/asset link that consists of 2 seconds before the marker and 2 seconds after it is created.
For each added restriction, a segment/asset link that consists of the restriction’s span is created.
When you drag a selection of multiple markers or restrictions to a sequence, the marker/restriction segments are displayed in the sequence sorted by timecodes in ascending order.
For each added stratum segment, a segment/asset link with the same duration is created.
When you add an individual thumbnail, a segment/asset link that consists of 2 seconds before the thumbnail and 2 seconds after it is created.
When you add a thumbnail span, a segment/asset link that consists of the span is created.
To add Storyboard items to a sequence:
Open the asset in the Asset Editor and click the Storyboard tab.
Open the sequence you want to edit.
Click the Asset Editor Timeline button to show the timeline.
Click the Asset Editor Source/Record Monitor toggle button to switch Asset Editor to Source mode.
To add items from a track or stratum, do the following:
Select the track or stratum from which you want to add an item.
Click the List View or the Card View button.
Select one or more marker(s) or restriction(s) or one segment in the segment list.
In Card view, you can also select an individual thumbnail or a continuous series of thumbnails.
To add an item from the Thumbnail layer, do the following:
Select Thumbnails from the layer selector.
Select an individual thumbnail. You can also select a thumbnail, press the Shift key and select the last thumbnail of the span you want to add.
Drag the selection to the Sequence Timeline and drop it into the position you want the segment(s) to appear in the sequence.
