Changing the Priority of Processes
The Process app offers you an option that allows you to change the priority of a process. Five priority levels can be shown for a process: Idle, Low, Medium, High and Urgent. Use the Change priority control to change the priority of processes that are not in a final state (Created, Pending, Running, Paused).
Note the following limitations for changing the priority of processes:
If the priority of a process can be changed is defined by the process provider. Therefore, you will see the Change Priority feature only for some processes; depending on the processes shown in the Process app, the Change priority feature might not be applicable to any process.
Currently, only Distributed Processing Jobs support the Change Priority feature.
The Process app only shows the priorities that have been defined by the source system of the process. Therefore, only a subset of the priorities might be displayed for a process or no priority at all.
The change process priority feature is only available for administrators or members of a group with enabled Master of Jobs entitlement.
The Change priority control is associated with the Priority column, which is hidden by default.
You can only change the priority of one process at a time, multi-selection is not supported.
To change the priority of a process:
Show the Priority column.
Click the Display Options drop-down arrow.
Select the Priority check box.
Click an area outside of the menu to apply your changes.
Click on the Priority of a process.
For processes that support changing the priority, a context menu opens.
Select the priority you want to assign from the context menu.
The new priority is assigned to the process.
