Renaming Assets
You can use the Browse app to rename clips and other assets in the Production Management database. If you want to rename a sequence, you can complete this same task also in the Sequence Timeline. For more information, see Renaming a Sequence.
Note that the following characters are not valid for Production Management asset names: / \ |
If you use an invalid character, a message opens when you try to save the changed asset name. Click in another area of the user interface to close the message. The changes made to the asset name are discarded.
To rename an asset:
In the Results area of the Browse app, right-click an asset and select Rename from the context menu.
The Rename Asset dialog box opens.
Type the new name.
Do one of the following:
To save the changed name, click Save or press Enter.
To revert the changed name, click Cancel or click the Esc key.
