Saving a Version of a Sequence
You can use the Save As feature to create and save a version of a sequence with a different name. The new sequence is treated as a duplicate in the Production Management database, and can be edited independently from the original.
n The Save As feature is not supported for Asset Management sequences.
To save a version of a sequence:
In the Sequence Timeline toolbar, click the turn-down arrow to the right of the Save button and select Save As.
The Save As dialog box opens.
Select a location to save your sequence.
The Save To field defaults to the location that you have entered in the Save User Settings.
For more information, see Setting the Default Save Location for New Sequences).
Click the down arrow to the right of the Save To field to select a new location.
n If you do not set a location in the User Settings, the sequence is saved in the same location as the original sequence.
(Optional) Rename the sequence.
If the sequence has the same name as a sequence in the selected folder, the Save button is grayed out. You need to rename the sequence or save it to a different folder.
Click Save.
The sequence is saved to the location defined in Save As window and it is loaded into the Asset Editor.
