Synchronizing a Sequence
If your MediaCentral Cloud UX server is licensed for Enterprise Editing, you can combine MediaCentral Production Management and MediaCentral Asset Management assets in the same sequence. When you mix assets from these two modules, the sequence is saved as a draft and must be synchronized before you can check the sequence into your Production or Asset Management system.
For more information, see Editing Mixed Sequences.
To synchronize a sequence:
  1. Save your sequence using one of the methods described in Saving a Sequence.
    If the latest changes to your sequence are not saved, the Sync option is disabled.
  2. In the Sequence Timeline toolbar, click the turn-down arrow to the right of the Save button and select Sync.
    The sequence is conformed to match the Production or Asset Management specifications (depending on where you initially created the sequence) and checked into the associated database.
