Copying Transcript Text to the Clipboard
You can copy the text of transcript segments to the system clipboard and paste them into another application. Note that copied segments do not include the speaker name and time-stamp information.
The procedure of copying segment text is the same independently if Edit Mode is enabled or disabled.
To copy the text within a segment to the clipboard:
  1. Do one of the following:
    • To select an individual word, click on the word.
    • To select several words, highlight the words by using the mouse pointer.
  2. Do one of the following:
    • Right-click the selection and in the context-menu that opens select Copy Text.
    • Press Ctrl+C.
To copy the text of an individual segment to the clipboard:
  • Right-click the segment and in the context-menu that opens select Copy Text.
  • Click on the segment and press Ctrl+C.
To copy the text of several entire segments to the clipboard:
  1. Select a segment, then press Shift+click to select a range or Ctrl+click to select individual segments.
    • Press Ctrl+C.
To copy text across segments to the clipboard:
  1. Click in a segment and move the pressed-down mouse pointer up or down to select text across segments.
    • Press Ctrl+C.
