Copying Translation Text to the Clipboard
You can copy the text of
Only for copying text within a segment Edit Mode needs to be enabled.
To copy the text within a segment to the clipboard:
Click the Edit Mode button so it turns blue. -
Double-click the segment that contains the text you want to copy.
The cursor is positioned at the end of the segment; if required, the Translation area display scrolls to show the cursor position.
Highlight words by using the mouse pointer.
Do one of the following:
Right-click the selection and in the context-menu that opens select Copy Text.
Press Ctrl+C.
To copy the text of an individual segment to the clipboard:
Right-click the segment and in the context-menu that opens select Copy Text.
Click on the segment and press Ctrl+C.
To copy the text of several entire segments to the clipboard:
Select a segment, then press Shift+click to select a range or Ctrl+click to select individual segments.
Press Ctrl+C.
