Renaming Transcripts
The transcript name is shown in the transcript selection list. A transcript name can be created as follows:
  • Set in the Transcript Name field in the Create Transcript dialog box.
  • Set in the Transcript Name field in a Media Analytics action in Rules Editor or Schedule Editor.
  • If the name was not provided, the transcript is named according to the audio track(s) for which it was created.
You can rename a transcript at any time, as described in the following procedure. Renaming a transcript is supported in both modes of the Transcript tab (Transcript and Translation).
To rename a transcript:
  1. Open the transcript selection.
  2. Hover the cursor over the transcript you want to rename.
    An edit button (pencil) is shown.
  3. Click the edit button.
    The Rename Transcript dialog box is shown.
  4. Type the new transcript name in the text field.
    The Save button is enabled.
  5. Click Save.
    The Rename Transcript dialog box is closed. The name change is directly applied.
    In the following example, A1 was renamed to English.
    For a renamed transcript, the track name is additionally shown in brackets. If the name cannot be shown completely in the transcript selection, you can see the full name and track in a tool-tip.
