Using Match Frame for Group Clips
You can use the Match Frame feature with group clips and sequences that include group clips.
To load the source master clip for the active angle of a group clip:
In Source mode, select the active angle for which you want to load the master clip.
Navigate to the frame that you want to match.
Click the Match Frame button.
The master clip for the active angle of the group clip is loaded in the Asset Editor, with the matching frame displayed.
To load the source group clip for a segment in a sequence:
In Record mode, navigate to the frame for which you want to load the group clip.
The group clip for the selected segment is loaded in the Asset Editor, in single-angle view. If you want, you can then use Match Frame to load the source master clip for the matching frame of the group clip.
