Writing Stories in Right-to-Left Languages
The script editor lets you write stories in right-to-left languages (for example, Arabic and Hebrew). Alignment of the text changes based on the following rules:
Automatic switching to right-to-left alignment:
Production cues and Story Form cells switch to right-to-left if more than 50 percent of the text in the production cue body consists of right-to-left characters.
Queue grid cells switch to right-to-left and right-aligned if the first character in the cell is a right-to-left character. If the cell is center-aligned by default, it will remain center-aligned regardless of cell content.
Manual switching
If focus is in any segment, alignment of all segments will be switched. Reloading the story will return the segment alignment to the default.
If focus is in the production cue body, only the current cue body alignment will be switched. Reopening the production cue returns cue body alignment to the default.
If focus is in a story form field, only the current story form field alignment will be switched. Reloading the same story form keeps the current field alignment. Reloading a different story form returns the field to the default.
To manually switch alignment of the segment that has focus, do one of the following:
Press Ctrl+Shift.
Right-click and select “Switch to RTL.” If the story is RTL, select “Switch to LTR.”
