Browse App Shortcuts
Keyboard shortcuts available when working in the Browse app are listed in the following table. Some keystroke combinations only work when the cursor is located in a certain section of the app; the Focus column in the table specifies the section of the app when that is the case. For more information on the app and its sections, see Using the Browse App.
Shortcut |
Description |
Focus |
Up Arrow Down Arrow |
Used to navigate to the previous / next asset |
Results area |
Shift (hold) + Up Arrow Shift (hold) + Down Arrow |
Used to select multiple consecutive assets |
Results area
Left Arrow Right Arrow |
Results area (Card View only) |
Shift (hold) + Left Arrow Shift (hold) + Right Arrow |
Enter |
If an asset is selected, opens the asset in the Asset Editor and in the defined default app (if applicable) If a folder is selected, opens the folder contents in the Results area |
Item in Results area |
Enter |
When renaming a folder or an asset:
Name field (edit mode) in Results area |
