Log App Shortcuts
Keyboard shortcuts available when working in the Log app are listed in the following table. Some keystroke combinations only work when the cursor is located in a certain section; the Focus column in the table specifies the section of the tab when that is the case. For more information on the tab, see Working with the Log App.
Shortcut |
Description |
Focus |
Ctrl+M (Windows) |
Creates a span with one frame duration |
Log app |
Ctrl+I (Windows) |
Creates a new span and sets the In point to the current timecode |
Log app |
Ctrl+O (Windows) |
Sets the Out point to the current timecode |
Log app |
F2 through F11 Shift+F2 through F11 (if configured)
Inserts the configured button or dropdown value to the corresponding span column in the Visual Text area. For a text component, sets the cursor in the text component in the Visual Logging area. If the component already contains text, the text is highlighted. Only available if the shortcut keys are configured for the used session template. |
Log app |
Esc |
Cancel placing a component |
Template |
Ctrl (hold) + Click |
Select multiple button or dropdown values for applying a color |
Template |
Shift |
Toggle the display inside the “Select a shortcut window” to show the shortcuts <Up-arrow>F2 through <Up-arrow>F11 or the shortcuts F2 through F11. |
Template |
Shift (hold) + Click |
Toggle the display inside the “Select a shortcut window” to show and select a shortcut <Up-arrow>F2 through <Up-arrow>F11. |
Template |
