Storyboard Tab Shortcuts
Keyboard shortcuts available when working in the Storyboard tab are listed in the following table. Some keystroke combinations only work when the cursor is located in a certain section; the Focus column in the table specifies the section of the tab when that is the case. For more information on the tab, see Working with the Storyboard Tab.
Shortcut |
Description |
Focus |
Ctrl+M (Windows) |
(Production Management) Create a new marker (by default, a marker with a red icon) |
Media Viewer Storyboard tab Browse app Search app |
Ctrl +number (top-row or numeric keypad)
(Production Management) Create a marker and set the icon color as follows:
The NumLock state must be enabled to use these commands on the numeric keypad. |
Ctrl+number (Windows) (top-row or numeric keypad) |
(Asset Management) Creates a segment as follows:
Shift (hold) + Up Arrow Shift (hold) + Down Arrow Shift (hold) + Click |
Used to select multiple consecutive markers, restrictions, or segments |
Storyboard tab |
Ctrl (hold) + Click |
Used to select multiple non-consecutive markers, restrictions, or segments |
Storyboard tab |
Up Arrow Down Arrow |
Used to navigate to the previous marker, restriction, or segment Used to navigate to the next marker, restriction, or segment |
Storyboard tab |
Ctrl + Shift + Left Arrow Ctrl + Shift + Right Arrow |
Used to navigate to the previous marker Used to navigate to the next marker |
Asset Editor Media Viewer |
Ctrl + C |
Copy the selected marker(s) or segment(s) |
Storyboard tab |
Delete |
Delete the selected marker(s), restriction(s) or segment(s) |
List view |
Delete / Backspace |
Delete the selected text or figures |
List view (Integer, Float, Date, Time, DateTime, Text) |
Enter |
Positions the cursor in the Comment field of the selected marker or restriction |
List view |
Esc |
Keep the already selected term |
List view (Legal list, thesaurus) |
Esc |
Discard your input, keep the original value and end editing mode |
List view (Date, Time, DateTime, Duration, Integer, Float, Timecode) |
Increase value Decrease value |
List view (Date, Time, DateTime) |
Move to the beginning of the field Move to the end of the field |
List view (Duration, Integer, Float, Timecode, Text |
Move cursor to the line above Move cursor to the line below |
List view (Text (multi-line) |
Home End |
Home End |
Move to the beginning of the line Move to the end of the line |
Left Arrow Right Arrow |
Advance to the input control at the left side Advance to the input control at the right side |
Advance to the character/figure to the left side Advance to the character/figure to the right side |
List view (Duration, Integer, Float, Timecode, Text) |
Tab
Advance to the input control at the right side within the attribute
Tab
Exit edit mode of non-text attributes n You cannot navigate between the properties of segments using the Tab key. |
List view |
Ctrl + A |
Select the entire text |
List view (Text) |
Ctrl + C |
Copy the selected text |
List view (Text) |
Ctrl + V |
Paste copied text, duration, timecode |
List view (Text, Duration, Timecode) |
Ctrl + X |
Cut the selected text |
List view (Text) |
Ctrl + Y |
Redo the action |
List view (Text, Float, Integer) |
Ctrl + Z |
Undo the input |
Space |
Checks or unchecks the in-focus check box |
List view (Boolean) |
