Removing an Asset from a Folder (Avid Production Management)
You can remove assets from their folders without deleting the actual media or the corresponding media files associated with it. This is different from the Delete operation as performing this action only removes the association of an asset with the folder it is in. In Delete, you can select which associated items from the asset you want to include in the deletion operation.
n With the Remove function, you can only remove assets one at a time. Selecting multiple assets to remove from a folder is not supported.
n You can use the Delete function to remove assets from multiple folders.
To remove a clip from its folder:
  1. Navigate to the location of the clip you want to remove.
  2. Do one of the following:
    • Right-click on the asset and select Remove from Folder from the context menu.
    • Select the asset, click the App Menu button and select Remove from Folder.
  3. A window appears asking if you want to confirm your selection of removing the asset from its folder.
  4. Select Remove.
  5. Your window refreshes and a notification appears confirming that the clip has been removed.
This process is different from deleting assets. For more information about deleting assets, please see Deleting Assets (Avid Production Management).
