Showing and Hiding Columns
Processes are displayed in the Process List, which provides basic information on each process in several columns. The following columns are shown by default: Name, Message, Created at, Progress, and State. The Name column is mandatory and cannot be hidden.
n The Cancel and Retry buttons that might be shown for a process are located within the Progress column. If you hide the Progress column, you also hide these buttons.
The Display Options menu shows you all columns that you can use in the Processes List area. In addition to the default columns, the following columns can be shown:
Updated at: Date when the process was last updated.
Ranking: Currently always 100 for Production Management processes and 1500 for Asset Management processes.
Priority: The priority of the process. Might be empty. For more information, see Changing the Priority of Processes.
Group: The group the process belongs to. Only shown if this information is provided by the process.
System Name: Name of the system on which the process was started. Only shown if this information is provided by the process.
System Type: Type of the system on which the process was started (such as interplay-mam). Only shown if this information is provided by the process.
Duration: Duration of the process execution (in format hh:mm:ss:msmsms). Only shown if this information is provided by the process.
Creator: Name of the user who initiated the process.
<custom columns>: If "user data fields" are configured on the MediaCentral Cloud UX backend, up to 25 fields from all source modules in total will become available as columns in the Display Options menu.
You can change the display format of the dates shown in the Created at and Updated at columns in the User Settings. See User Settings.
You can reorder the columns in the Processes List area by simply dragging and dropping the column to a new position. Additionally, you can use your mouse to click on the divider between two columns to adjust a column to a custom size. Except Message, you can sort each column by clicking on the column header.
To show and hide columns in the app:
Click the Display Options drop-down arrow.
A list of columns appears. The columns that are currently used are highlighted with a blue check mark.
Select the columns you want to add or deselect the columns you want to remove. Name is a mandatory column that you cannot remove.
Do one of the following:
Click an area outside of the menu to apply your changes.
Press Esc to revert your changes.
To rearrange the column order:
Click and drag a column head to the left or right column.
A blue line shown to the left of the column indicates the drop target.
To adjust the column width:
Click the column divider and drag it to the left or right.
