Asset Editor Shortcuts
Keyboard shortcuts available when working with the Asset Editor are listed in the following tables.
For more information on this utility and its sections, see The Asset Editor.
Shortcuts with Focus in the Media Viewer
The following table lists shortcuts you can use when the focus is in the Media Viewer in the Asset Editor.
Shortcut |
Description |
Focus |
Space bar |
Play or pause play. |
Media Viewer |
Home |
Move to the beginning of a clip or sequence. |
Media Viewer |
End |
Move to the end of a clip or sequence. |
Media Viewer |
I |
Insert a Mark In point. |
Media Viewer |
O |
Insert a Mark Out point. |
Media Viewer |
Shift+I, Shift+E |
Remove a Mark In point. |
Media Viewer |
Shift+O, Shift+R |
Remove a Mark Out point. |
Media Viewer |
Ctrl+\ |
Match Frame |
Media Viewer |
Left Arrow |
Move 1 frame back |
Media Viewer |
Right Arrow |
Move 1 frame forward |
Media Viewer |
Down Arrow |
Zoom in to a section of the timeline by 50 percent. |
Media Viewer |
Up Arrow |
Zoom out from a section of the timeline by 50 percent. |
Media Viewer |
Shift+Up Arrow |
Zoom to show the entire sequence |
Media Viewer |
J, K, L |
Media Viewer |
Ctrl+J, Ctrl+K, Ctrl+L |
Globally |
Ctrl+Shift+Left Arrow |
Go to the previous marker. |
Media Viewer |
Ctrl+Shift+Right Arrow |
Go to the next marker. |
Media Viewer |
Alt+Left Arrow |
Move 10 seconds back |
Media Viewer |
Alt+Right Arrow |
Move 10 seconds forward |
Media Viewer |
Alt+E |
Go to Mark In point |
Media Viewer |
Alt+R |
Go to Mark Out point |
Media Viewer |
Esc |
Switch between Source mode and Record mode |
Media Viewer |
B |
Perform an overwrite edit |
Media Viewer (Record mode) |
V |
Perform an insert edit or splice-in on shotlists and Sequences (news sequences not included) |
Enter (Windows) |
Select the timecode display to enable keyboard entries. |
Media Viewer |
plus ( + ) |
Begin Timecode entry mode, relative forward |
Media Viewer |
minus ( - ) |
Begin Timecode entry mode, relative backward |
Media Viewer |
S |
Open the Select Folder for Subclip dialog box. |
Media Viewer (Source mode) |
A |
Move the position indicator to the previous segment in the Timeline. The position indicator moves to the first frame after the cut. In a News Sequence, the position indicator moves to the closest segment on an active track. |
S |
Move the position indicator to the next segment in the Timeline. The position indicator moves to the first frame after the cut. In a News Sequence, the position indicator moves to the closest segment on an active track. If you move the position indicator to the end of a sequence, the position indicator moves to the final frame of the sequence. |
Group clip shortcuts |
Alt+1 through Alt+9 |
Select the active angle of a group clip. These keystrokes apply only to camera angles 1 through 9. n In a multi-angle view, camera angles are numbered from upper left and left to right. |
Media Viewer |
Alt+Up Arrow |
Select the previous angle of a group clip in the current bank. |
Media Viewer |
Alt+Down Arrow |
Select the next angle of a group clip in the current bank. |
Media Viewer |
Alt+, (comma) |
Display the previous bank of camera angles |
Media Viewer |
Alt+. (period) |
Display the next bank of camera angles |
Media Viewer |
Ctrl+Z (Windows) |
Undo an action |
Media Viewer |
Ctrl+Y (Windows) |
Redo an action |
Media Viewer |
Sequence Timeline Shortcuts
Keyboard shortcuts available when working with the Sequence Timeline are listed in the following table. For more information on the app and its sections, see Editing a Sequence.
Shortcut |
Description |
Focus |
Ctrl+S |
Save the sequence. |
Sequence Timeline |
Delete |
Delete the selected segment. |
Sequence Timeline |
I |
Sequence Timeline |
O |
Sequence Timeline |
Shift+I, Shift+E |
Sequence Timeline |
Shift+O, Shift+R |
Sequence Timeline |
Alt+E |
Sequence Timeline |
Alt+R |
Sequence Timeline |
Esc |
Sequence Timeline |
Ctrl+X Shift+Ctrl+X |
Cut selection (Lift) Cut selection (Extract) (Shortcut works after clicking a segment to select it. Does not work with mark In / Out points.) |
Sequence Timeline (Sequences only) |
Ctrl+C |
Copy selection (Shortcut works after clicking a segment to select it. Does not work with mark In / Out points.) |
Ctrl+V Shift+Ctrl+V |
Paste selection (Overwrite) Paste selection (Insert) (Shortcut works after clicking a segment to select it. Does not work with mark In / Out points.) |
X |
Cut selection (Extract) (Works with mark In / Out points.) |
Z |
Cut selection (Lift) (Works with mark In / Out points.) |
backslash ( \ ) |
Add a transition at a cut point (e.g dissolve). |
Sequence Timeline |
Ctrl+E (Windows) |
Split a segment into two segments n Use Ctrl+E if you are using macOS Sonoma. |
Sequence Timeline |
Ctrl+Shift+X (Windows) |
Extends a segment into another timing block. |
Sequence Timeline (News sequences) |
B |
Sequence Timeline |
V |
Sequence Timeline |
N |
Perform a replace edit. |
Sequence Timeline |
Shift+drag |
In an insert edit, override snap (sticky) points. |
Sequence Timeline |
Ctrl+click (Windows) |
Snaps the position indicator to the closest cut of the enabled tracks.
Sequence Timeline |
A |
Sequence Timeline |
S |
Sequence Timeline |
T |
Mark In to Out around the maximum extent of the current segment in the Sequence Timeline. (Blue position indicator identifies the current segment.) Active tracks define which segments are used in the selection. |
Sequence Timeline |
Up arrow |
Zoom out of a sequence by 50 percent |
Sequence Timeline |
Down arrow |
Zoom in to a sequence by 50 percent |
Sequence Timeline |
Shift+Up Arrow |
Sequence Timeline |
Alt+drag zoom handle |
Enlarge or reduce one end of the zoom region (asymmetrical zoom) |
Sequence Timeline |
Right arrow |
Sequence Timeline |
Left arrow |
Move 1 frame back |
Sequence Timeline |
Sequence Timeline |
Sequence Timeline |
J, K, L |
Sequence Timeline |
Space bar |
Play or pause play |
Sequence Timeline |
Ctrl+Z (Windows) |
Undo an action |
Sequence Timeline |
Ctrl+Y (Windows) |
Redo an action |
Sequence Timeline |
With trim indicators active |
M |
Trim the segment’s selected end by 10 frames earlier. |
Sequence Timeline |
comma ( , ) |
Trim the segment’s selected end one frame earlier. |
Sequence Timeline |
period ( . ) |
Trim the segment’s selected end one frame later. |
Sequence Timeline |
slash ( / ) |
Trim the segment’s selected end 10 frames later. |
Sequence Timeline |
Shift+[ |
Trim from start of segment to the position indicator (trim top). |
Sequence Timeline |
Shift+] |
Trim from the position indicator to the end of a segment (trim tail). |
Sequence Timeline |
With Dual-Roller trim indicators active |
Shift+M |
Sequence Timeline |
Shift+ comma ( , ) |
Sequence Timeline |
Shift+period ( . ) |
Sequence Timeline |
Shift+slash ( / ) |
Sequence Timeline |
Sequence Timeline |
Alt+Up Arrow |
Sequence Timeline |
Alt+Down Arrow |
Sequence Timeline |
